| Message |
In your first post you said it was part 15191, that's just a right-angle adapter, on the passenger side of the engine--Courtesy does label this as a "CONNECTOR-3 WAY" even though it's not. In your second post (to which I'm replying to now...) you're saying it's for 15192? That one DOES use a plug (PLUG-BLIND) but it's labelled "TUBE ASSY-OIL", and NOT "CONNECTOR-3 WAY". This is on the driver's side. In any case, the passenger side (15191) doesn't use a drain plug--just the banjo bolt. The driver's side (15192) does use a drain plug, but I'm afraid I have no idea what its specs are and to be honest, I would just get a Nissan part to avoid getting one that's too long or too short.
